I just got a call from the dish installer. I'm the second call of the morning, so he will be here in a few hours. He said that this was going to be his first hopper install so we would be learning together.
Thanks for the tip, I will share that with him. What happens if you don't?
If he needs help remember we are always here!
Remind him NOT to plug the Joey's into the MoCA line until after the Hopper has downloaded its software and is at its activation screen!
my install will be here in 10 minutes...
... and he was gone in about 10 minutes. He showed up for a two Hopper - three Joey install without a duo node.
My install is scheduled for this afternoon. Should be fairly simple. 1 Hopper, 1 Joey. My only concern is that my oldest HD set, the Sony 65", is DVI and component, no HDMI. It works with the Cox HDMI port using a DVI adapter, so I'm hoping it will work with Dish.
Thanks, I hope you're right. My fallback is a 40" flat panel in the 2nd bedroom with HDMI, but I really want that 65" to work.It should, you just have to use the red white audio cable along with the DVI to HDMI adapter.
The Hopper has HDMI and component out.My install is scheduled for this afternoon. Should be fairly simple. 1 Hopper, 1 Joey. My only concern is that my oldest HD set, the Sony 65", is DVI and component, no HDMI. It works with the Cox HDMI port using a DVI adapter, so I'm hoping it will work with Dish.
Install proceeding a bit slowly, the dish, hopper, and joey's (2) are installed, we're waiting for the hopper to config itself. We've been looking at a "Aquiring sattelite signal." screen for some time now, like 20+ minutes. This is the second time we've waited at this screen for some time now, the first time we sat at "Aquiring sattelite signal." for about 20 minutes, then the screen wen't black, we rebooted. Now we're about 20 minutes in again.
The spec sheet I saw shows composite (red/white/yellow), not component. The only HD output is HDMI.The Hopper has HDMI and component out.
