I have 2 722 receivers and a 612. To support this I currently have three coax cables that run from my Dish into a distribution panel inside my home. All the cable outlets inside my home also run into this distribution panel. Inside this panel is where the dixplexers for the 722 are located for feeding back the TV2 signal to other rooms.
I plan to switch to a 2 Hopper / 2 Joey system which will require a Duo Node. So, can the Duo Node go inside this distribution panel? I assume the Duo Node will go inside this Distribution panel and connect to the three cables already coming from my Dish? And then the 4 outputs from the Duo Node will connect to the various rooms in my house that are already wired to the panel.
This all sound right? Seems simple to me but wondering if there is a catch somewhere.
