Install question
TCarson
9
I have a dish 500 dual lnb and a 722 reciever. Can i just run a line from each lnb to the back of the 722 and run an additional cable out of the 21-60 out to another tv and have both tvs working without using any switches or splitters?
Yes. But if you arent getting your lnb's confused, a dual lnb only 'sees' one satellite at a time. Both tuners will work but you will only recieve one satellite.
But if what you are actually referring to is a dish pro twin, (has two 'eyes') then the answer is still yes. And it will pick up 2 sats.
Or are there 2 dual lnb's on this dish?
If thats the case then yes, one cable from each lnb will work.
"Yes" on the RF output. But what are you doing with a D500 going to an HD receiver? It very likely has a DishPro or DishPro Plus twin, rather than a "dual". Do you have a receiver connected now? What does menu-6-1-3 say about the device and switch? And satellites? Most HD channels are not on 110/119.
yes its a dish pro plus. has two outputs and one input i know I will not get hd but that is the box I have so I was going to use it. So each output carries both 110 and 119? I know the input is for a second dish which I will not use
Yup; the switch is internal. You can feed a 722 with one cable from your DPP twin using the separator that comes with the 722. Lots of missing HD though.
7100/7200 Receivers
Question about upping from AT120 to AT200 --- DIRT?
