Install Diagram of 3 STBs with OTA and diplexers...
Sarcoptic
60
Bondurant, IA
As the subject states just looking for an install diagram using the newer wiengard antenna and 3 boxes using diplexers. The one in the FAQ is with the older stealth antenna and not using diplexers....
i have a 3 box setup. you will have 2 satellite feeds and one line from from your antenna coming into your home. they will all go into a multiswitch, from the multiswitch there will be one line going to each box. that is where the diplexor is used. the one line is split with the diplexor...one to the satellite feed and one to the antenna feed on the back of the voom box..
Local Signal Hookup
WHEW .... Thank GOD for this forum ...explain inside
