Big factor when using in-line amps to drive a long cable run is their saturation/compression level.(That specification is more important than just db gain alone) Are you going to be driving it beyond it's limit in signal level? This can cause more problems than originally experienced. I've removed more amps**, installed by others, than I have installed*** because of overload and the resulting problems it produced.
**cheap "no name" or store brands ***Channel Master, Winegard, Jerrold, PTC.
In OTA antennas, a good quality PRE-Amplifier can be the difference from marginal to rock solid on weak signals. But here again, Overload specification is important. A strong signal, along with the weak, could push the amplifier into saturation, distorting and wreaking havoc on all the signals.
For satellite reception, if it's weaker signals that are desired, the only solution that works is a larger dish.
