IE can't see the internet
navychop
Stop overfishing Panthalassa!
65,200
34,977
Northern VA
After much internal debate, I installed IE7, which shortly thereafter ceased to work. It said words to the effect "can't see the internet." Firefox works fine. But with IE out, I can't do a Windows or Microsoft Update. Plus, certain other sites don't work "correctly."
So I uninstalled IE7. Now IE6 is back, but it has the same problem- it thinks I'm not online.
I've run AdAware and Spybot. No help.
Any ideas on what to try next?
I've got to get IE working, even though I use it as little as possible. I could try reinstalling IE7, but I have the feeling that will do no good.
Go to File and see if Work Offline is checked. Another thing to check is Tools, Internet Options, Connections, LAN Settings, make sure everything is unchecked.
Are you using Norton Anti-virus? There is a known bug in it that does what you are describing, and the bug can be started with a up date to IE6 - and probably by switching to IE7. Try disabling Norton if you do use it.
First, thanks to all who answered.
Have you checked your settings under internet options by chance to see if something is amiss?
Yes, I did that. No joy. Didn't think about the Work Offline bit, so double thanks on that one.
Yes, I use Norton, so I tried disabling auto protect. Did no good. But then, your comment reminded me of my Nvida firewall, which I use in place of the Windows firewall. Bingo! I turned it off, and with Norton on or off IE started working again. So I turned the Nvidia firewall back on, and IE continues to work. Then I got the blue screen of death. However, on reboot, it looks like IE works, Nvidia and Norton are on, everybody's playing nice and no BSD. Yet, anyway. I think I'll stick with IE6 for a while longer.
Thanks again for all your help. I surely needed it.
Glad you got it working. I was reading to chime in about Norton. ANYTIME anything quit working on my system, turning off Norton was the answer (Ophoto, Amazon etc all had problems at some point or another) Finally I dumped Norton, and have had NO problems since. It's not enough to 'allow sites' , or fiddle with settings, turning off was the only thing that worked.
Just for anyone's FYI.
Someone brings up a good point
Hi all
