I had decided to put the bullseye back on after running the corotor for a year or so.
i have some agile channel modulators and thought i would modulate a couple more channels into my antenna stream so i needed to be able to run a multiswitch to accmodate a couple more receivers.
to my surprise..the bullseye had been laying around in a storage building-it had all this white oxidation crud inside it. i removed the lnbs and tried cleaning most of it out.
put the lnbs back on and put it on the dish.
reception was not nearly as good as my corotor II. Ku and c was both down quite a few points over the corotor. I thought in the past when i used that feed it was as good or better.
could that chaulky white crud cause poor signals?
