Hello - I have the signal from my Voom STB distributed to two other locations in my house so I wanted the capability of having a UHF remote as I did with DirecTV. Following some recent threads I set out to accomplish this and it is working very well. You only need 3 things:
I chose to buy an extra remote - nabbed on Ebay for $18. Then I ordered the remote Xtender battery module from:
http://www.homeautomationnet.com/Shopping/remote-control-accessories.asp
and that is $24.95, plus shipping (you do not need the rest of it, just the additional transmitter module). For the whip antenna, I nabbed the old one off of my DirecTV STB. You can make one using a 1 foot chunk of coax with an F connector. Chop the connector off the opposite end if there is one, then strip off the outer insulation and the foil or braided shielding. You can leave the inner insulation on.
Then connect the antenna to the jack marked "UHF" on the back of the Voom STB. Then insert the Xtender transmitter in the Voom remote in place of one of the batteries. That's it! In my house it works everywhere I need it to - not sure of the range. If you need to extend the range, place the antenna as high as you can. If you are using the coax antenna you could use a longer chunk of cable with only the last foot stripped of shielding - then tack that up high.
This is all possible due to the fact that Motorola built in UHF remote capability to the generic STB design but when Voom chose not to specify UHF remotes, Motorola left the feature in the STB. It is a coincidence that the remote Xtender module happens to be on the correct UHF frequency to work with the STB since there are other frequencies either could have been set up for.
- Voom remote (extra one off Ebay or your original one)
- A remote Xtender transmitter battery module (see link below)
- A small whip antenna with F type connector (see below)
