I need an arm for von weise 36 v motor?
skipticum
40
ottawa
Where can I buy (just) the arm to go with a von weise motor (36 volt)?
I have a von weise actuator with perfectly working motor (very clean), but the outer and inner tubes are badly rusted and fused together. I separated the tubes from the motor, but I couldn't pull the inner tube from the outside shaft. Both shafts are badly pitted to the point where they are not salvageable. I need a new arm...Thanks.
depending on length, some are still available. ( parts) thats for a smaller arm (18 inch) inside tube.
Von Weise has went back to selling them you might can call them and ask about replacement parts.
Me , I would just clean it up best as you can , lube/grease the acme nut located inside smaller tube clean the screw for the main drive. and put it back together.
Polarity problem with DMS BSC621-2
Saginaw Reed Switch Question
