First I want to say thanks for an awesome site. I have learned a tremendous amount over the last few months of searching and reading. And now on with the questions! I have a Coolsat 5000, a Fortec 80cm mounted on a Sg-2100. I am using the Invacom QPH-031 with one of the linear outputs going into port 1 of a coolsat diseqc switch and one of the circular outputs going into port 2. The Lat and Long for my area is 39.17 and 93.59. After mounting the mast and checking it for plumb I set the dish bracket at 24 and the elevation on the motor at 51. Then I mounted the dish on the mast and pointed it south using a compass and correcting for deviation. Using a signal meter going directly into the lnb I cannot pick up my Southern most sat which I am assuming is IA6, is this correct? My settings for the lnb are single 10.75 diseqc switch 1.0 committed 1 for linear and for circular 11.250 switch 1.0 committed 2. Are these the correct settings for this LNB? Am I correct in my understanding that the sat beam comes down at a higher angle than the dish is pointing and then the beam is bounced back to the lnb? The previous question is due to a concern about possible signal obstructions. I have the dish mounted on the gable end of my house as near to the peak as possible. It looks like I may have a blind spot in the middle of my arc caused by my neighbors roof but it is close if the signal comes in above the dish like I think it does, the roof shouldn't be my problem. I am considering using a tripod mount and a five foot mast to get it up in the air. Will ordinary antenna mast work or will I need something heavier? Any help is greatly appreciated
Thanks in advance,
Jason
Thanks in advance,
Jason
