Greetings,
I am trying to set up my dish for the first time. I purchased a new 3-beam dish. I identified the one possible location on my property where I think I can get a signal. I set the angles and mounted the dish. Now I am playing with the azimuth and the different transducers trying to get a signal …
When I choose either transducer 30 or 32 for the 101 satellite, I get around 88% on a clear day. The same direction gives me 92% on the other satellites. But, even with these settings, when I turn the unit on, it says “searching for signal” and never gets any further (eventually the message goes away). I have gone back and forth checking to see if the settings remain the same between on/offs.
When I do the system check the access card comes up ok, so I know it isn’t a problem with that.
The only curious thing I should mention is that I don’t get any signal at all (i.e. zero) on any other transducers (only 30 and 32).
Does anyone have any idea why the signal meter screen would say I have a solid lock on both satellites, but the unit still says “searching for signal”???
PLEASE HELP … I am totally at a loss with what else to check or do to fix this.
Thanks so much!
~ At-wits-end ~
Thanks so much!
~ At-wits-end ~
