I couldn't adjust the POTs to get an output voltage beyond 11-12 volt here
  • Thread starter Thread starter Kyyo
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
Kyyo
San Jose
I am new to electronics and have been exploring easy to make DIY things for a while now. I am using the following circuit to make a voltage regulated high current DC power supply. The problem is, I couldn't adjust the POTs to get an output voltage beyond 11-12 volt. The DC output is always between 11 - 12 volts, neither less, nor more. By the way, the trafo is 12-0-12 5 Amp, and I am measuring no-load voltage with a digital voltmeter.
My questions are:
  1. Is the circuit correct, regulated voltage at the base of 2N3055 will regulate the voltage at its emitter - is this principle true?
  2. Is keeping one of the terminals of the POTs open (Not Connected) a good idea? Should they service the purpose in this circuit?
  3. If I want to troubleshoot, what are the test points and what are the expected voltage or other attributes I should look for.
Thank you a lot for your help, in advance.
The new Mi Box is out
