But their entire bill is probably more.And They Pay Less Per Month For Hd
I've got a vaguely similar question about OTA antenna and my new 722. Before I got my dish installed this weekend, I had already set my TV up and hooked up to our roof top antenna on the building. I am receiving about 16 channels of HD. I hooked the antenna up to my 722 (same wire, unplugged from TV and plugged in 722) but when i went through the add local channels, it only finds a measly one channel. Is the box that junky I'm missing the other 15 channels? I'd really like to be able to record with the DVR. One of our local PBS stations has 4 HD feeds, but I can't receive any of them OTA on the 722. Yet I was just watching them when antenna is hooked to TV.
The scan feature has a lot to be desired on Dish Receivers. Try putting the channels in manually,you will need the transit numbers for the channel to do it this way. You can add them once they are locked in. If you need your transit numbers, you can find them at antennaweb.org.
What a royal PITA and non intuitive thing to mess with! I finally figured it out. You have to go System setup > HDTV setup and change analog type to offair. I went from 1 OTA to 22.
Why is it the installer knows nothing, tech support knows nothing, but I find the answer by poking around?
