Hs 17
sam1070
SatelliteGuys Guru
145
5
yakima wa
is there any way I can gurentee I will get the hs 17 as I will be ordering 4 4k clients and I would like them to be able to view 4 k content
So only way to guarantee is to have your upgrade order processed for it.. The HS17 is not given out to new customers.. Also be aware with the HS17 you can only 2 4K programs at a time
ask for it, if they show up without it, send them away
but i really dont know why anyone would want one
Call 1-800824-9077 HS17 can feed 2 4K streams at once -Hs17 is for existing customers only
There was a post a couple of days ago by an installer claiming that he is using the HS17 for new installs, so it may be regionally dependent.
Reactions: whitewolf8214
Why would DirecTV give their absolute newest hardware only to existing customers? Seems backwards. Not complaining. Just doesn’t seem right?
I think its just the initial release, you'll see others getting it eventually ...
It does make sense, seeing the Not new subs rarely get anything ... period.
Its all about getting the new sub ...
Of late, they have been giving big discounts to not new subs.
There is slight lag in the wireless clients but nothing worse than I had with an HR44 and they're in rooms with little use and no channel surfing. The wired 4K clients have no lag at all.
Turn off HS17 Video Bridge
Next Generation DTV NOW Coming This Spring
