HR44 and Slip30/Skip30
upsss
529
68
AZ
Anyone with the HR44 able to change the default Slip30 to Skip30? I was able to change it on the HR34 but not on the HR44.
I haven't read anything about it before. You are using the same method I assume.
I don't know which method you use, do you have the HR44? I used the method Iceberg posted here long time ago and like I said, it worked on the HR34.
I have an HR20 and an HR24. It works on them just fine. Like I mentioned, I haven't heard of it one way or the other for the HR44.
You haven't heard of it because most of the HR44 are brand new installations and the people don't know their Slip from their Skip.
Anyway, I figured out how to fix it, simply search for 30SKIP instead of SKIP30 and to switch back also use 30SLIP instead of SLIP30.
We already knew that, well at least us in this and many other forums :)
Sent from my iPad 2 using SatelliteGuys
Isn't this what you were doing before that didn't work for your 44 ?
Sorry for your confusion, but I've always seen it as 30skip/slip.
I just did a search of the forum and there were 12 examples of skip30 with most of them being corrected by other posters with the proper 30skip.
The 30skip/slip has been available for years, outside of the ce.
Six Minute Reboot
This Location is Not Authorized
