HR44-200/500 CE's for the Weekend of 10.10
dfergie
Proud Staff Member
Staff member
HERE TO HELP YOU!
Systems in this CE
HR44-200/500
Window of opportunity to download: Friday October 3rd, 2014 11:00PM - 2:30AM ET
Saturday October 4th, 2014 11:00PM - 2:30AM ET
Risk Level for this Download:
LOW - Customer Candidate
Improved/Updated
  • Under The Hood / Stability
Background Send Report Feature
  • Press & Hold List button for 5 seconds
  • Double-bonk sound will be heard to indicate start of process
    • In some cases, the double-bonk is suppressed if the STB is plugged into a Dolby Digital supported device and the Dolby Digital audio track is selected
  • Check Menu > Settings & Help > Settings > Info & Test > More System Info for status
    • Code will be seen next to ‘Completion Code’ list item, check back as it may take a few minutes to complete
    • Number at end of report key indicates status
      • 0 – Success
      • 9 – No Internet Connectivity
      • 10 – Transmission started
      • 11 – Transmission in progress
      • 12 – Transmission timed out
  • There is still a one-report per hour limitation
  • Please try and press & hold the LIST key as close to the actual problem being reported as possible
  • Please continue to provide the report key when reporting problems
Notes
  • PLEASE MAKE SURE TO REPORT ALL ISSUES WITH THIS RELEASE.
  • You may lose your guide cache
  • Please allow up to 24 hrs to restore your full 14 day guide
  • Your STB may restart during idle time within the first 24-48 hours of CE download
  • Please do not report sluggishness or missing search results within the first 12 hours
  • Please send logs along with all reports, including MRV issues. When possible please use REPORT ALL.
H2x/ HR2x CE's for the Weekend of 10.10
HR34 - 700, HR44 -700 CE's for the Weekend of 10.10
