With an HR22-- is there a way to turn off the 2nd tuner? I recognize that this would prevent me from watching 1 program while recording another, but I don't need that functionality.
My reason for removing the 2nd tuner has nothing to do with cost. I'd be happy to pay for it, if that would solve my problem.
The problem is that I'm trying to figure out how to make my new SWM install handle 12 tuners, while some people have told me that it is limited to 8. I thought that I could get 99% of the benefit of a DVR while only using one tuner in each box.
I can't disconnect a wire on the back of the unit because only one wire goes into the box. Also, the unit only has one authorization card, so I can't remove a 2nd card.
I have read in past threads in another forum that on HRXX series, you can turn off a tuner in the sattelite setup screen. I have never tried it though, but you might want to try re-running setup to see.With an HR22-- is there a way to turn off the 2nd tuner? I recognize that this would prevent me from watching 1 program while recording another, but I don't need that functionality.
repeat satellite setup...at satellite setup screen change tuners from dual to single...that should remove the channel for the 2nd tuner from the swm lnb, allowing to add another channel...hope this helps...good luck
Old thread came up from my search.
During setup I switched from dual to single as I had only one line going to the HR 22. I then added another line but could get no signal on tuner two.
I switched this cable to tuner 1 and got signal indicating that both lines were live. However when I went to check sat signal only line 1 was reporting. I then did a system reset and all is fine now, thanks.
