HR22-100 problem.
terry1
21
My HR22 will drop the audio portion of a program for about a second or two as often as every five to ten minutes,and,at other times, it will be OK for a few days.The dropping of the audio is more common than not.
The channel is not always the same.
I am sure that my audio equipment is fine because if I go back a few seconds the missing audio is still in the same place(time).
Anyboby else having this problem?
Hoping there is a cure.:(
Try rebooting the recvr first and see if that helps ...
Menu, Set Up ,System Set Up, Reset, Restart Recvr, dash.
Extremely Long Cable length problems
Going HD: rooftop antenna or DTV?
