HR21-ALL CE Release - Saturday 3/15 ONLY
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,043
448
Central Michigan
Systems in this CE / Version
HR21-700
HR21-200
HR21-100
HR21 - CANCELLED entire weekend
CHANGES FROM THIS RELEASE:
  • 01 - 1xFF performance and appearance
  • 01 - Guide scrolling performance
  • 01 - GameSearch avoids partial recordings while searching for games
  • 01 - Stability improvements
  • 01 - Supports the AM21, DIRECTV's external ATSC tuner
  • 01 - Autorecords with Boolean Search logical operators appear in TODO list
  • 01 - Channel up and down updates the selected item in the Prioritizer
  • 01 - Playlist new displays the recording date
This is the first CE of this cycle. The previous CE was released nationally 3/12.
This is a summary of the keyword search power tricks from the programmers (for
reference):
Simple Grammar:
[{AANY/AALL} <tokens>] [{NNOT} <tokens>] [TTITLE/NNAME] [{CCHAN} <number> [<number>]]
BOOLEAN LOGIC:
“AALL” => (this is the AND boolean operation) all the following words must be contained within the program (title, about, name, episode, category) in any order “AANY” => (this is the OR boolean operation) at least one of the following words must be contained within the program (title, about, name, episode,
category)
“NNOT” => (this is the NOT boolean operation) exclude any programs that contain any of the following words in that search string
The AANY and AALL keywords should appear as the first word in the search string in order to set the search mode.
The NNOT keyword may appear anywhere and all words following the NNOT keyword are considered words to exclude.
SCOPE FILTERS:
TTITLE => Limits the search to only the Title field of the Programs NNAME => Limits the search to only the Name field (e.g. Actors, Director) of the Program CCHAN => Limits the search to only the specified channel range (example CCHAN 500 510, or CCHAN 500 for a single channel)
Some sample queries are:
AALL racing car NNOT nascar => finds all shows containing “car” and “racing”
(any order/position), but excludes the show if “nascar” appears
AALL hanks tom NNOT vinci => finds all tom hanks movies/shows but excludes
the movie if the word “vinci” appears (e.g. da vinci code)
AALL hanks tom NNAME => finds all tom hanks programs where he is an actor
AALL hdtv football => finds all high definition football
programs (note you can include category labels in the search and “HDTV” is same as “High-Def”)
AANY usc ucla NNOT football => finds all usc and ucla events/shows, but
excludes football events
oakland raiders NNOT miami => finds exact match for “oakland raiders” but
excludes show if “miami” appears (e.g. excludes games with Miami Dolphins) AANY lakers clippers CCHAN 700 730 => finds all games with the Lakers or Clippers on only channels 700 through 730 AANY lakers clippers CCHAN 710 => finds all games with the Lakers or Clippers on only channel 710
As of last notice this is about a 50/50 liklihood for Friday night. If it does not happen tonight, then there is a better chance for Saturday night.
Please check back shortly after 11pm and we'll let you know if it is available or not.
I'm surprised that nobody made a comment about this one new item:
I would if I still had the OTA antenna connection but the installer cut the line to the antenna and used that as one of the lines. I guess the D setup doesn't work with a combiner.
You don't have the AM21 yet, it's the add on ATSC tuner that's not release yet.
They don't officially support it but you can make it work if you can put the BBC like:
antenna/multiswitch->BBC->diplexer->cable->diplexer->STB
The BBC needs to be inside since it's not rated for outside usage. Try it and if it works for you great, if not you're back to what you had before. If it does work for you, if you do run into sat reception problems later remember to remove it to make sure it's not causing the problems.
Well, If I did go OTA again I'll probably just do an attic antenna with a drop down to the a AM21. I'm not even sure what a BBC is Outside of theBritish Broadcasting Corporation. :)
BBC = B-Band Converter (the small box which hooks to the satellite input of the receiver). It converts the Ka-lo output of the LNB (with Directv 10) from 250-750 MHz to 1650-2150 MHz. If you get a SWM it has a built-in diplexer (and the BBC isn't required).
Any audio issues showing up with the 0216 version? I wish I had tried the download on Saturday even though it was officially postponed. I'd be gladly testing 0216 now. The audio issues with 0206 - which is now the national release - are driving me nuts.
HR20-ALL CE Release - Sat 3/15 ONLY
D11-100
