HR21 -200 & -700 (HD-DVR) CE Release 2/1 & 2/2 ver: 0x1F8
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,043
448
Central Michigan
Software Download Window:
Friday: February 1, 2008: 11pm - 2:30am ET
Saturday: February 2, 2008: 11pm - 2:30am ET
PLEASE READ THIS FIRST! CE DOWNLOAD WARNINGS / AGREEMENT
PLEASE READ THIS SECOND! CE DOWNLOAD INSTRUCTIONS
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
CHANGES FROM THIS RELEASE:
  • Minor UI polish for guide favorites
    Boot behavior improvements
    Minor Audio improvements
    Stability improvements
    Performance improvements
    Increased keep 10 episode option
CHANGES FROM PRIOR RELEASES (since last national release):
  • 01 - Random video freeze after extended period of inactivity
  • 01 - Random system lockup after extended period of inactivity
  • 01 - No sound effects over optical audio connection
  • 02 - Switching from dynamic/static IP Networks
  • 02 - Audio not heard over HDMI connection, for Media Share
  • 02 - Static Information Screen - DoD Comming Soon
  • 04 - PPV price not appearing in info screen
  • 04 - Slow navigation in the To Do list
  • 04 - Unable to show “Channels I Get” for current favorite in Favorites screen
  • 04 - Updated status in system info panel
  • 04 - Audio drops when catching up to live TV from live buffer
  • 04 - Game Lounge Sign-up
  • 04 - Black screen on channel change
  • 04 - Failed recording
  • 04 - No trickplay after running system test
  • 04 - Incorrect content in showcases screen
  • 04 - Access to record options when no scheduled episodes are present
  • 04 - Able to delete bookmarks during playback
  • 04 - Missing folder icon
  • 04 - Audio options update with a channel change
  • 04 - Frozen animated thinking icon in “Please Wait” OSD
  • 04 - Purchase options update correctly after cancelling a purchase
  • 04 - Correct behavior of live TV transitioning from playback
  • 04 - Failed data acquisition not timing out
  • 04 - IP address update detection
  • 04 - Lockup caused by keyword search
  • 04 - ITV slow loading with addition frame filters
  • 04 - Text missing on Game Lounge games
  • 04 - sluggishness due to multiple instances of slow scheduler updates
  • 04 - Reset resolution and aspect ratio on Reset Defaults
  • 04 - Reset Resolution after Reset Everything is performed
  • 04 - Random Insert valid access card OSD displayed
  • 05 - Audio features for NASCAR HotPass
  • 05 - Improved system startup time
  • 05 - Frozen video on PPV when purchased after preview window
  • 05 - Searching/Recent Searching By Channels
  • 05 - Warning Icons in Playlist
  • 05 - Title Displayed with Parental Controls turned ON, during DELETE
  • 05 - Duplicate Titles in Showcases
  • 05 - "Please Wait" not clearing on ToDo List
  • 05 - DoD Queue remain on reboot, even if guide is not loaded yet
  • 05 - Dolby Digital Audio Fixes
  • 05 - HDMI Audio on Media Share Features
  • 05 - Stability
  • 06 - Tuning and recording iTV channels
  • 06 - Pause/Play not continuing at paused position
  • 06 - Switching from no-VOD home page to VOD home page
  • 06 - Mediashare play/stop issues when going into standby
  • 06 - Resolution handling with Native on
  • 06 - Guide never reloads after Antenna Setup
  • 06 - FFWD 1X with VOD content
  • 06 - Stuck on step 1 of 2 after software download
  • 06 - No bonk over optical
  • 06 - Degradation of HDMI Dolby Digital when switching from Media share playing Dolby Digital audio
  • 06 - Stability
  • 07 - Change “As Broadcast” to “Original Format” in HDTV screen
  • 07 - Archived Guide Data fails to restore
  • 07 - Guide Data causes random system hang during archiving
  • 07 - Reboot after 30-40 hours
  • 07 - Random system hang due to internal processing
  • 07 - Trickplay stability
  • 07 - iTV mix channel
  • 07 - Repeating VOD title on homepage with arrow down
  • 07 - Clock round-up
  • 07 - XM background appearing on playback
  • 07 - Stability
  • 07 - Modem firmware upgrade
New feature(s)
  • 04 - On-demand feature enabled
  • 04 - left arrow back
  • 04 - video in Media Share
  • 04 - 30 skip also
  • 04 - Hide SD Duplicates
  • 04 - quick CC toggle
  • 04 - etc.
  • 06 - Boolean keyword search
Release notes for the -200 & -700 are identical (although CE release cycle history may have varied)
Does this mean VOD will finally be enabled on the HR21-700?
I try to go there now and all I get is a thud.
If it is activated on your account, then yes. I'm not sure how long they are delaying VOD activation, or if they are even doing them right now on HR21? They have many already active with HR20's that also are testing HR21s.
They used to activate it through a batch process that detected the software you were running and looked for the CE versions. Given the increased amounts of posts about it not working over the last few CEs on HR21, I have to wonder if they are still doing this right now?
Hopefully those of us that have the HR21-700 will be able to get on demand with this CE. Keeping my fingers crossed. I'll let you know after download.
On demand was enabled on the CE:03:04 build, tonights build is CE:03:08, so it's been out for the past three CE's, this is #4.
Okay help me out since I am new to this. What is the top items in the different colors mean? IS that the bugs that will be fixed if we download the new software ,or is that the bugs you will get if you down load the new software?
Every week or so there is an updated CE sent out. They add one version to the notes until DirecTV is satisfied and makes a national release to all receivers.
Then the process starts over again :hatsoff:
You got it. I'll add it to the notes.
grydlok got it a quick minute before you in the hr20 thread. You can have the big prize too :)
Internet Access finally fixed
I used to be unable to connect to the internet (was getting a self addressed IP (169.*.*.*)). This CE seems to have fixed that.
Haven't tried the daisy-chain ethernet port yet.
DoD still not working though.
And it seems that all my HD channels do now broadcast with pillar boxes.
Everything seems fine after the download. I see the shaded in lines for the unsubscribed channels. Alot of new channels with the -1 after them most dont do anything as of yet. No Dod but i did notice that when i hit the ondemand button. I now get the the doink noise were before i got the blue screen telling me about vod so that parts different. Plus i also notice the 5 to 10 episodes in the recording. Plus it also said whole series. Hopefully i can use the vod soon. I also noticed now that in playlist it has vod downloads which are empy as of now, But still different.
Problem: VOD downloads but won't play
I see it downloading but when I hit play I get just the grey screen on the top right side. Last version it worked fine. It would start downloading and I could play right away. Left it downloading something again and will wait to see if it only plays when it reaches 100%.
Anybody else with similar problem?
In my haste last night I tried the keyword search 'iwantmyvod' and got nothing. Today the list is populated and I am able to download and watch content. I was *not* able to watch as it downloaded through.
I've had my HR21 for a week now, and was suffering some serious TiVo withdrawals, particularly the 30 sec. skip function. Last Sunday, I discovered this site looking for some remedies, and the CE program is just what the doctor ordered. Although last night's download stumbled on my first two attempts, after unplugging the unit and reconnecting, the third time was the charm. Everything went as planned, I've got my SKIP function, and the menus seem to be working a bit better. I did notice that some of my recurring recordings were missing from the ToDo list and I wonder if that was the fault of the software update.
I'm not sure of what to expect from the DoD function as yet - I'm still trying to navigate the menus with some efficiency.
Oh, and is "Season Pass" a dirty word amongst HR21 owners? :)
so it sounds llike you're having the same problem. have you downloaded antyhing to completiion to see if it will play?
Guide under HD
HR21 DOD tip
