HR20 Recording at Will
drain69
17
Can someone please tell me how to manage recording on the HR20. Programs such as Will and Grace and others are just recording at will what do I need to do to modify the programs that are in the to do list from not recording. I have been manually going in and hitting the record button in the to do list which seems to remove them but if a wait a few weeks the list re populates with new garbage.
Thanks,
Can you explain a bit? You mean it's recording repeats you don't want?
To modify a series link you go to the prioritizer (season pass manager), select the offending series link and choose record series from the menu. Change what you want and done your way out.
Hr20 will not record a series
I have tried to record a series with 2 "R"s and from the 'record series' menu tab. The dvr will record only one episode. The 'to do list' will show no more episodes, even though there are multiple episodes under the 'episode tab' and on the guide. In essence the series is the same as a single recording.
Dishnetwork to Directv switch
NBA-TV HD added
