HR20 Manual Recording Option
btmccain
16
Arab, AL
Apparently the manual recording option has a bug in it. I had mine set to record Jay Leno nightly. If you do the regular season pass it also records the 2:00 a.m. Jay Leno. Anyway, it started setting manual recordings of its own one hour before the normal start time. Also, it was two recordings of the same. On the info screen after recording it lists numerous show that appeared on NBC that day. Is anyone else having this problem?
Go into the series tab and set it to record "First run only"
No HD in FOX KTXL Sacramento
72.5 sat issue
