HR20-700 / Sep. 22 / {CE:09:05a} - 0x19e
Blurayfan
54
From Tom at http://www.dbstalk.com/showthread.php?t=100255
Systems in this CE / Version
HR20-700 {CE:09:05a} - 0x19E
Window of opportunity to download:
Saturday; September 22, 2007 11PM - 2:30AM ET
Download Probability: 90%
Be sure to monitor the threads and chat room to check on final availability
The Contents of the Release: (Differences based of 0x18a National Release)
  • Items from CE:09:01
  • Items from CE:09:02
  • Items from CE:09:03
  • Items from CE:09:04
  • Items from CE:09:05
  • Items from CE:09:05a
Improved
  • Prioritizer Screen
  • Navigation to PIG (Picture In Graphics) removed. (Trick Play Still works), to improve interfacing with UI
  • Stability
  • Several user interface polishing and fixes based on CE reports
  • DoD: Misc. Reported issues fixed
  • DoD: Performance improvement
  • User interface polishing
  • DoD UI: Restored CHANNEL UP/DOWN in the Homepage Left Menu.
  • DoD UI: Homepage "tuning" fix for consistent prevs channel
  • DoD UI: Added “On Demand” to quick menu after “My Playlist”
  • DoD UI: UI Polishing/fixes
  • Caller ID (no specifics on what)
  • UPnP issue that certain networked Cameras could crash the box.
  • A plethora of fixes to issues identifed in the previous CE's
  • Several UI Fixed and Polishing
  • Fixed the CE Introduced issue with items in the ToDo List, but ultimately not recording
  • DoD UI: "More VOD" in ever page
  • DoD UI: Misc. Items
  • DoD: Corrected - Not being able to resume playback of a currently downloaded program
  • DoD: Corrected - Listing Performance
Updated
  • History list now includes conflicting program
  • Unwatchable content is no longer kept in the disk
New feature(s)
  • Keyword search finds category (eg HDTV or sports)
  • [strike]Caller ID for Type 2 (aka Call Waiting, off-hook, ect); Caller id reverted to 0x18a version[/strike]
  • Start/resume to manual
  • Left arrow mimics "BACK" when practical
  • Long channel name in search by channel
  • Ability to hide SD channels if duplicate HD channel with same number exists
  • Support for Remote Booking
  • DoD: Pressing INFO when over the DoD channel goes directly to the "ALL" List
Notes
  • There are other misc. updates in the release
  • GUIDE DATA WILL NOT BE CACHED they are enhancing pieces of the guide data, which means you WILL LOSE your guide data after the install. It will repopulate over the next 20-24 hours. This is only valid if you are coming from 0x18a, if you are on 0x19* you are not expected to lose your guide cache
  • DoD GUIDE DATA will most likely be lost after you reboot the system.
  • This is the fifth CE in the cycle... So the risk level is lower then the previous ones, but there is still a risk involved. Please only download this CE release if you are willing to take that risk
19* , autorecord with keyword not working
New HR20-700 CE tonight only
