From DBSTalk.Com
LE Risks and Guidelines
How to Force Download an LE Release
Be sure to monitor the Living on the Edge forum HERE at Satellite Guys for changes in probability and go status!
HR20-700 {CE:09:02} - 0x194 Announcement
Systems in this CE / Version
Window of opportunity to download:
Friday; August 31, 2007 11PM - 2:30AM ET
Saturday; September 1, 2007 11PM - 2:30AM ET
Current Probability: 85%
Be sure to monitor the threads and chat room to check on final availability
The Contents of the Release: (Differences based of 0x18a National Release)
Improved
Updated
New feature(s)
Notes
Notes regarding VOD
Per Tom at DBSTalk
Remote Booking code will be in this CE. The DIRECTV.COM site will not be ready immediately, but get your accounts online now! DIRECTV wants to enable your accounts the moment the site is ready--but you have to do your part.
You do not need network connections nor VOD to participate in Remote Booking, so everyone can play!
o my knowledge, we do not need to do anything special in our accounts. They will find us.
If you have VOD, Remote Booking will be able to schedule both VOD and non-VOD titles. If you do not have VOD, you will still be able to schedule regular shows.
Lastly, network connections are not required for Remote Booking of regular shows. (I think that means you won't get email confirmations, tho.)
Verified. CE'ers, to get their HR20s on Remote Booking, will need them on the Internet. So connect them to the Internet, get your account setup, and download tonight's CE.
Then a bit of patience until they have the site ready for us.
- Items from CE:09:01
- Items from CE:09:02
Improved
- Prioritizer Screen
- Navigation to PIG (Picture In Graphics) removed. (Trick Play Still works), to improve interfacing with UI
- Stability
- Several user interface polishing andf ixes based on CE reports
Updated
- N/A
New feature(s)
- Keyword search finds category (eg HDTV or sports)
- Caller ID for Type 2 (aka Call Waiting, off-hook, ect)
- Start/resume to manual
- Left arrow mimics "BACK" when practical
- Long channel name in search by channel
- Ability to hide SD channels if duplicate HD channel with same number exists
Notes
- GUIDE DATA WILL NOT BE CACHED they are enhancing pieces of the guide data, which means you WILL LOSE your guide data after the install. It will repopulate over the next 20-24 hours. This is only valid if you are comming from 0x18a, if you are on 0x190 you are not expected to lose your guide cache
- This is the start of a new CE cycle, and as such... this one has a higher level of risk then other CE's. Minor/Non-Critical issues are expected, but the system should still be more then acceptable for normal to above normal usage. If you have any concerns, or this is your one and only, or primary HR20... please consider these facts before downloading the CE... as always... outside the window, you can re-download the national release.
Notes regarding VOD
- The Keyword search: IWANTMYVOD will be DISABLED. There will not be another keyword to enabled it in this CE. (This is not a joke, hidden message, or anything... there will not be a keyword in this CE version to enable it)
- Those that have 0x190 and have enabled VOD (verifable by seeing the QUEUE option in the scheduler), will remain enabled. Regardless, if DirecTV has completed the backend part of your account
- You MUST enabled VOD, before downloading this CE.. 0x190 will not be re-offered.
Per Tom at DBSTalk
