This is correct, the PTAT will record all four major locals (NBC, CBS, ABC, & FOX). These will go to the PTAT folder on your Hopper and auto delete when the time set on the PTAT setting screen is reached, mine is set to eight days. If you want a particular show to not auto delete and to save to the My Recordings folder on Hopper. You can select this recording in the PTAT folder and select Save Series. This will then create a separate timer that will allow those recording to stay on your DVR. If you no longer want to save these recording, you need to Delete the Timer. I hope this helps!
