HOW TO SEND CBAND SIGNAL TO...
calmazan2002
9
usa
more than one tv?
what equipment is needed to split c band signal to a slave receiver on a second tv?
thanks
A C-Band LNB that has two outputs for two recievers. Or a "Loop out" (F connector)on the first reciever to the second one. Option one shares the satellite, option two shares the transponder.
With a dual output lnbf, you can also feed a 3x4 switch for up to 4 receivers or a powered or unpowered 4x8 switch for up to 8 receivers in the house. :) See how much money you could spend ? :)
Servo action
Will Ku band work with a 7.5 foot mesh dish?
