How to reformat a Dish formatted EHD?
isaacmorseMI
4,734
Southwest Michigan
I used a WD Essentials EHD to transfer programs from my 722K to my Hopper. I now want to use it with my computer again. However my computer is not seeing it at all. What am I doing wrong?
Uh, well it should detect it. What OS do you have? If Vista/7, click Start, right-click Computer, click Manage, click Disk Management, make sure you select the EHD and not any other drive, right-click it, click Format, click Quick Format, filesystem NTFS (or whatever else you want,) allocation unit size Default, OK.
Hope this helps.
Assuming Windows 7.....
Right click "Computer"
then click "Manage"
then click "Disk Management"
make sure you are working with the external disk....
I kind of forget from there but you may have to delete any partitions before formatting it.
Got beat on that one! :D
RickDee said:
Will try that later. Thanks!
Sent from my iPad 2 using Forum Runner
I have the same problem. I interrupted the dish format on a new EHD. Now it has only 500 gb instead of the 1.5 tb available. I want to somehow reformat the EHD to get all of the available space.
