How to paint/clean your Primestar
Anole
11,819
14
L.A., Calif.
How to clean & paint your Primestar
Painting dishes is a question that comes up from time to time.
Here's the cleaning and painting rules for all those old crusty Primestar, Channel Master, & Andrew molded dishes out there.
Primestar bought Channel Master dishes, then Channel Master was bought by Andrew. :cool:
Recommended Procedure to Re-paint Channel Master SMC/TMC Reflectors
Cleaning Process:
The cleaning process will depend on the degree of contamination.
You will need the following materials:
  • Chlorine Bleach (Clorox or equivalent)
  • TSP-PF All Purpose Heavy Duty Cleaner (Savorgran or Equivalent)
  • Rubber gloves
  • Heavy duty sponges
  • Soft bristled brush
  • Bucket
  • Hose or source of water
Mildew and Dirt Removal:
  • Remove by washing with a solution of ½ cup of TSP-PF dissolved in 3 quarts of warm water and add 1 quart of chlorine bleach. Use solution to scrub area thoroughly using brush or sponges.
  • For uniform results, treat entire area not just contaminated area. The bleach should kill the fungus growth and remove stains. TSP-PF removes dirt and grime and wets the surface so that the bleach can work.
  • If stains remain, use second application.
  • When mildew is gone, rinse thoroughly with clean, warm water and dry surface completely if painting is required.
  • The solution will NOT prevent mildew growth.
Repaint Process:
  • Scuff the face of the dish lightly with an abrasive pad or sandpaper to improve adhesion. Mask the logo or scuff it to paint over it.
  • A new logo can be applied over the painted logo.
  • Wipe the face of the dish with a dry rag to remove dust.
  • Apply an even coat 1.0-1.5 mils (.0010-.0015 inch, .025-.040mm) of water-based acrylic paint to the reflector.
  • Allow to cure.
  • Apply a second even coat 1.0-1.5 mils if necessary.
Notes:
  • The choice of color is up to the user.
  • Channel Master standard light gray color is Pantone Matching System (PMS) #428C
  • This process is not for hydrophobic coated reflectors
  • Be careful not to remove the existing surface finish, only scuff lightly and clean thoroughly.
  • The procedure can be used to paint the back of reflectors as well. In this case there is no existing finish to consider.
ref: Andrew: Satellite Broadband Products
Here's my method:
Got to your local discount store. Get you some 99 cents-a-can flat black. Get about three cans, heck they're 99 cents!
Take your dish, wash it well with soap and water and a scrubbrush. Rinse well, let dry. Rough it up a bit with sandpaper, blow off the dust with shop air, or dust with a clean rag.
Put dish on saw horses once dry, paint with paint. Keep putting paint on it until its uniform color that you like.
Install your dish and enjoy.:cool:
8 Satellites on one dish
Getting the Traxis 3500
