I have a c band pole from a radio shack dish that does not go into the ground, j hooks in a concrete pad are used to secure it to the pad.
Made a cube in the ground 22x22x27. Should be more then plenty to hold the dish.
However, when you make a concrete pad, do you use regular cement, pure?, or do you mix with pea gravel?
