GEOSATpro How to I get a signal connecting the RCA plug output to older TV
hawaii
13
Honolulu, Oahu
The MicroHD works great with HDTV HDMI output. I wanted to use a portable Sanyo 13inch tv/vcr to set up my dish outside. There is no signal when attaching to the small tv with RCA of the MicroHD.
The MicroHD has been successfully updated using Iceberg and SatelliteAV's instructions. I have attempted to change MicroHD output settings from menu screen while it was attached to HDTV but the small tv does not respond. The SanyoTV RCA input is currently working great with a Channel Master Digital converter. The TV is used daily to record local TV shows. So it is not the TV but the MicroHD not sending a signal thru RCA cable.
Any solutions to get it working?:confused:
You should not have to do anything to get it working; just make sure the special 3.5mm adapter plug is pushed in all the way and that red,white and yellow cords are correct.
Mine works fine using the RCA my test TV.
After reading your reply, I sprayed the 3.5mm plug contact cleaner and gave it solid push in. It started to work! :)
Thank you Jaytee4320 for solving that one!
GEOSATpro Universal Remote for MicroHD
GEOSATpro How to add satellites from Asia & Pacific?
