How to hook up since I have a KU LNB and a C lnb?
two4two
48
I see it has only the one coax in, so does it do both C and KU? How do I hook up BOTH my coaxes (C and KU) to the single coax input?
All single tuner DVB satellite STBs have one Satellite Input.
Use a switch to select between the two LNBFs. Your choice of a 22khz or a DiSEqC switch.
See the Switches Simplified FAQ ... in our FAQ section.
If your Ku LNBF is Standard and not Universal, I might go with a simple 22khz switch.
It has just two inputs. Just what you need. ;)
Diseqc switches typically have four inputs, for easy future expansion.
The receiver can be set up to use either. :)
Or even a combination of both.
iPhone 4
How to connect an OTA to the microHD.
