Hi Guys, I am REALLY lost now.
I got the dish 10 feet mesh on the pole. I went and connected ONLY the 2 lnb cables to the pansat 3500 receiver. I am not connecting for now the other cables that come from the Actuator or the Servo Montor.
Then I power on the receiver and go to Setup, Antena, then it shows a bunch of satellites. What do I do here? Do I need to change the values according to what LBNs I am using (they are listed below, C/Ku)? I get no signal anywhere, I pressed everything, smart scan, went into each satellite, etc , etc, and get nothing. I just do not know what to do here and the manual is not a great help for me who has never done this.
Please help me, this should be the last part of this project. Thanks.
By the way I live in tampa, FL.
Latitude: 27° 58' North
Longitude: 82° 32' West
Chaparral C/KU band Corotor ll Plus Combo Pack, Feedhorn w C and KU LNBs
The Corotor II Plus is designed for systems which require reception of both C and Ku-band signals. The Corotor II Plus is primarily for reception of satellites in the United States.
Corotor 2 Plus Features:
Patented probe for C-band reception
Unique Low-loss dipole antenna for Ku-band reception
Receives linear C-band signals in the 3.7-4.2 GHz Range
Receives linear Ku-band signals in the 11.7-12.7 GHz range
Built in the Chaparral tradition of quality, the Corotor II Plus is the ideal choice for systems which require reliable performance.
C-Band LNB Specifications:
Model Number SLT-120C17+
I/P Frequency 3.4-4.2 GHz
O/P Frequency 950-1750 MHz
LO Frequency 5.15 GHz
LO Initial Accuracy ± 1MHz @ 25° C
Stability (-35°C to +52°C) ± 2.0 MHz
LO Phase Noise <-85 dBc/Hz (@10kHz)
Noise Temperature 17 °K
Conversion Gain 60 dB
Gain Flatness ± 1 dB /36 MHz
± 3 dB /800 MHz
Image Rejection 40dB (min.)
Third Order Intermodulation -50 dBc (min.)
1 dB Compression Point 0 dBm
DC Voltage 10.5 - 21.0 VDC
Output Impedance 75 W F-Female
Output VSWR 2.5 : 1
Max. DC Current 200 mA
Output Port Number 1
Waveguide Interface WR-229
Operation Temperature -35°C to +52°C
KU LNB Specifications:
Model Number 770LSKU
I/P Frequency 11.7-12.2 GHz
O/P Frequency 950-1450 MHz
LO Frequency 10750
Initial Setting Accuracy at 23 °C ± 500 kHz
LO Stability (-35 °C to +52 °C) ± 2.0 MHz
LO Phase Noise
kHz offset) -60 dBc/Hz @ 1
-80 dBc/Hz @ 10
-90 dBc/Hz @ 100
Noise Figure 0.8 dB (max.)
Cross Pol. Isolation 25 dB (min.)
Conversion Gain 50 to 62 dB (typical)
Gain Flatness ± 0.5 dB/24 MHz
O/P Spurious -60 dBm (min.)
O/P Power @ 1 dB Compression 0 dBm (min.)
O/P VSWR 2.0:1
O/P ports 1
O/P Port Type 75 W F-Female
DC Voltage 10.5 - 21 V DC
Current Consumption 110 mA
Waveguide Interface WR-75
Working Temperature -35 °C to 52 °C
Humidity 0-100%
± 3 dB /800 MHz
Output VSWR 2.5 : 1
LO Frequency 10750
LO Phase Noise
-80 dBc/Hz @ 10
-90 dBc/Hz @ 100
O/P VSWR 2.0:1
O/P ports 1
Humidity 0-100%
