How to change 811 UHF Channel?
pfriederichs
4
Problem is i got 2 811's and saw a post on here that you can change the UHF channel on them -- I dont see any info on this in the manual and the 2 keep interfering with each other...
Thanks in advance -- Paul
it's in the manual page 25 ;)
1. Press SYS INFO button on the receiver's front panel.
2. Press and hold the SAT button on your remote control for
about three seconds, until all of the mode buttons light up,
and then let go of the SAT button.
3. Use the NUMBER PAD buttons to enter any number
between 1 and 16.
4. Press the POUND (#) button. If you entered the address
correctly, the SAT mode will flash three times.
5. Press the RECORD button.
6. Press the SELECT button to close the System Information
screen.
Also, since you have 2 811's, turn them both off, then turn ONLY the one you want to change remote address ON with the button on the front of the unit. (Don't power on with the remote)
Then press SYS-INFO button on the front of the 811 to get to the right screen.
Follow the instructions BFG gave to change the address.
