I'm trying to connect a single LNB to a 4x4 multi switch so I can get locals. I also have a dual LNB used for the networks.
I've got the single LNB connected directly to my receiver trying to get aimed on the 72.5 bird. However, I'm not quite sure how. All I can do is get aimed up on the 101 with all transponders showing good signal strength. In another thread I was told to use the receivers signal meters on the 101 to aim is so only even transponders are peaked and the odds are at 0. I can't figure out how to do this. If I lose the odds, I also lose the evens. My main dual lnb dish is pointed at the 101 and is aimed in a SW direction. Does the one for locals also get aimed in a SW direction and does it need the same elevation as the other dish?
Thanks!
Buster
Thanks!
Buster
