So after I adjusted the post and added additional support. I took a level out and stuck it against the post. Now the bubble was between the two line. No matter front or left or right. Now the bubble though being between the two lines was slightly toward the one line. Not dead on. The bubble in the top of the post included the same thing. But in order for me to adjust it just a tad. I would have to move the side mounts over and since I started with it center and put the mounts on. This is were everything with motor seemed to settle. So thus once again between the two lines on the level. just a tadd over one way. Not exactly between the two lines.
As before I seem to be hitting more satellites in the arc.
Plus I'm sure I'm still off since I still don't show anything in order if I use usals.
Good enough? Answer would be appriciated.
Thanks,
Josh
Thanks,
Josh
