How far can you turn an SG2100?
TiminMb
700
Winnipeg, Manitoba
How far can you turn an SG2100? For instance, can I turn it far enough to point to 107 degrees on compass? I'm trying to get Hispsat 30, but on USALS its "out of range". Should be at around 107 degrees for my location, 6 degrees off the horizon, but I'm not sure how far an SG2100 will turn. Will it go right to 90 degrees if centred on due South?
That should work then. I'll have to for the first time go up on the roof and have someone on the other end of the phone pressing the nudge button while I get it roughly in position.
As Iceberg pointed out you may have to use DiSEqC 1.2 for satellite positions at the ends of your arc!
DiseqC switch isolation
Satellite Update via Pansat 3500 SD card
