There could be another possibility. The actuator may have some or to much play in it. I'm talking about between the actuator and the dish. There are two pivot points where this could happen. Either or both could cause a simular problem. This happened to me when I changed an H to H birdview mount that the birdview motor had gone bad to an actuator. My cheapo self wouldn't pay $200 bucks for a replacement motor for the birdview. I opted instead to get an actuator at a considerably cheaper cost. Apparently my welding was off a bit and when I go uphill with the actuator, I have no problems, but when I go downhill I can't hit any "sat" except the furtherest one, as in the last one, that's programmed in. I've tried and tried, but can't get it right. I've decided to get the birdview motor,which I have, but now I can't seem to find the other parts needed, that I removed to put the actuator on. These parts include a bracket, a couple of gears to go on the shaft of the birdview motor and a chain. I've actually found the chain. I need those gears, I wish I had a picture, I really don't know what all is missing. I hope they turn up, as I never throw anything away, they must be around here somewhere. Oh well.
Al
