How do you scroll Dish Remote Grid
jwill
56
14
When I go into Dish remote and select "Grid", the grid show my local stations but ends around channel 100 and I have been unable to make the scroll bar work (it shows a solid line as if that's all there is.) Is there a way to scroll (or page) the grid down to view stations like USA, TNT, SyFy, etc? I am almost positive that I use to be able to scroll it. My only solution so far as been to select things without using the grid.
Jim
Jim
One known problem is that with IE8 you must select compatiblity mode. Otherwise the scroll bar doesn't work.
Thanks, that explains why I thought it was working at one time (I was using IE7.) I hope they fix this because I have the same problem using Bolt on my Blackberry.
Jim
102 minutes that changed...
Moved home and now my ota timers don't work right.
