How can I see what Sat and TP channel is?
GO to the channel that you want to see on the television for example weather channel 214 then with you remote press menu 6 1 1 which should give you satellite 119 transponder 6
Yep that is the way to do it. What channel you having problems with or just curious.
I have just noticed that my 61.5 satellite I use to use fro Skyangle which came in on transponders 23 and 32 I beliver dish network has dropped that sigal strength as it was a modified 77 now 60 on t25 and 68 now 49 on t32 but my 61.5 t14 is now 82. Just to give you an idea my 119 t 14 is 78 with my 110 t14 is 77 with my 118.7 t16 is 70. Keep in mind these are all the new modiifed lower readings. Hope this helps anyone.
My CNN is getting picked from 119, is there way to force it to 61.5?
Put foil over your 119 LNB, then do a check switch (it wont detect 119) then go to 200 for CNN or 140 for ESPN and it should come in in MPEG 4 SD... at leas that is the theory we are working with right now
Dumb Question Re 61.5 pointing
OTA with E*
