Thanks for all the help. Here is some additional info that might help. Some of this info will be a repeat. This should be all the info that I can get. I have two dish500 dishes. The main dish has two LNBs and the second dish has one LNB. I do have a DP34 switch. On the switch, there are three satellite cables going in(three is all that can be used) and two lines coming out for my two receivers. Hope this additional info helps out. There are two other quick questions.
One, is there a way to put another LNB on the second dish to pickup 61.5. I am in the D/FW area and the three I am getting now are 110, 119, and 148. I am not sure which ones are the main and which are the second dish.
Two, if I have to get another dish, I have an old one and the LNB I had about four years. It is a DirecTV dish. Will this dish work? As you can tell I am a novice at this so I assume I would have to get an installer for this.
If any other info needed just let me know.
Thanks again,
Mulder
