How can I fix this?
dickdxr
6
I need Help!!!
I need help! I can get high signal readings but no quality -0- on any satellite I go to. I'm not sure if my menu or dish settings are correct. I have been struggling with this stuff all freaking day long....
I have all the Longitude and Latitude setting. I live in Houston, TX (77539). The closest Satellite to me is G3, at 95 West. But I can't even get any signal quality there.
My equipment is as follows:
Viewsat VS2000 Extreme,
Fortec Star 90cm (35") Dish,
STAB HH-90 Rotor
Invacom QPH-031 Quad LNBF, LO10.75/ HI 11.25GHZ
4x1 Diseqc Switch
Please help.
I would stick to one side of the LNBF at a time. If you use the linear side the L.O. should be 10750 (When using the circular side set your L.O. to 11250)
I would remove the motor/switch and try to find and store a few satellites first!
Here are all the angles you will need for all the satellites in your area!
Code:
                  San Leon, TX 77539
     Latitude 29° 27.960'N Longitude 95° 2.070'W
              Sat Name Sat Lng Az(t) Az(m)   El  Skew
            Telstar 12   15.0W  94.9  91.0 -0.0 -60.2
          Intelsat 901   18.0W  96.5  92.5  2.6 -59.9
                 NSS 7   22.0W  98.5  94.6  6.1 -59.4
          Intelsat 905   24.5W  99.9  95.9  8.3 -59.1
          Intelsat 907   27.5W 101.5  97.6 10.9 -58.6
         Hispasat 1C/D   30.0W 102.9  99.0 13.1 -58.1
          Intelsat 801   31.5W 103.8  99.8 14.4 -57.7
          Intelsat 903   34.5W 105.5 101.6 17.0 -57.0
           AMC 12/T 11   37.5W 107.4 103.4 19.7 -56.2
               NSS 806   40.5W 109.3 105.4 22.3 -55.3
             Pas 3R/6B   43.0W 111.0 107.1 24.5 -54.4
                Pas 1R   45.0W 112.4 108.5 26.2 -53.6
          Intelsat 705   50.0W 116.2 112.2 30.5 -51.4
          Intelsat 707   53.0W 118.6 114.7 33.0 -49.8
          Intelsat 805   55.5W 120.8 116.9 35.1 -48.4
                 Pas 9   58.0W 123.1 119.2 37.1 -46.8
              Amazonas   61.0W 126.1 122.1 39.5 -44.7
            EchoStar 3   61.5W 126.6 122.6 39.9 -44.4
             Rainbow 1   61.5W 126.6 122.6 39.9 -44.4
      Estrela do Sul 1   63.0W 128.2 124.2 41.0 -43.2
          Brasilsat B2   65.0W 130.4 126.4 42.5 -41.5
          Brasilsat B1   70.0W 136.5 132.5 46.1 -36.8
              Nahuel 1   71.8W 138.9 134.9 47.2 -34.9
             DirecTV 1   72.5W 139.9 135.9 47.7 -34.1
                 AMC 6   72.0W 139.2 135.2 47.4 -34.7
                 SBS 6   74.0W 142.0 138.0 48.6 -32.4
            Echostar 4   77.0W 146.5 142.6 50.3 -28.7
                 AMC 5   79.0W 149.7 145.8 51.4 -26.1
               Nimiq 2   82.0W 154.8 150.9 52.8 -21.8
                 AMC-9   83.0W 156.6 152.6 53.2 -20.3
          Brasilsat B3   84.0W 158.4 154.4 53.6 -18.7
              AMC 2/16   85.0W 160.2 156.3 53.9 -17.1
                 AMC 3   87.0W 164.0 160.0 54.5 -13.9
                  IA-8   89.0W 167.9 163.9 55.0 -10.5
             Galaxy 11   91.0W 171.8 167.9 55.3  -7.1
             Nimiq 1/3   91.0W 171.8 167.9 55.3  -7.1
          Brasilsat B4   92.0W 173.8 169.9 55.5  -5.4
             Telstar 6   93.0W 175.9 171.9 55.6  -3.6
             Galaxy 3C   95.0W 179.9 176.0 55.6  -0.1
             Telstar 5   97.0W 184.0 180.0 55.6   3.5
             Galaxy 4R   99.0W 188.0 184.1 55.4   7.0
       DirecTV 1R/4S/8  101.0W 192.0 188.0 55.0  10.4
                 AMC 4  101.0W 192.0 188.0 55.0  10.4
            Spaceway 1  102.0W 193.9 190.0 54.8  12.1
                 AMC 1  103.0W 195.9 191.9 54.5  13.8
                AMC 15  105.0W 199.7 195.7 53.9  17.0
           Anik F1/F1R  107.3W 203.8 199.9 53.1  20.6
           DirecTV 6/5  109.5W 207.7 203.7 52.1  23.9
            EchoStar 6  110.0W 208.5 204.6 51.9  24.6
            EchoStar 8  110.0W 208.5 204.6 51.9  24.6
               Anik F2  111.1W 210.3 206.4 51.4  26.1
         Solidaridad 2  113.0W 213.4 209.4 50.4  28.6
              SatMex 5  116.8W 219.1 215.1 48.2  33.3
             DirecTV 5  119.0W 222.1 218.2 46.8  35.7
            EchoStar 7  119.0W 222.1 218.2 46.8  35.7
 EchoStar 9/Telstar 13  121.0W 224.7 220.8 45.4  37.8
            Galaxy 10R  123.0W 227.2 223.2 44.0  39.7
             Galaxy 12  125.0W 229.5 225.6 42.6  41.5
         Galaxy 13/H 1  127.0W 231.8 227.8 41.1  43.1
  Telstar 7/Echostar 5  129.0W 233.9 229.9 39.5  44.7
                AMC 11  131.0W 235.9 231.9 38.0  46.1
             Galaxy 1R  133.0W 237.8 233.8 36.3  47.4
                AMC 10  135.0W 239.6 235.6 34.7  48.7
                 AMC 7  137.0W 241.3 237.4 33.1  49.8
                 AMC 8  139.0W 243.0 239.0 31.4  50.9
            EchoStar 1  148.0W 249.6 245.7 23.7  54.7
            EchoStar 2  148.0W 249.6 245.7 23.7  54.7
   Satellite Finder is (c) Copyright 2004, P. Lutus
I have just completed installing my Fta system. But I can only get channels from Intelsat 5, 97W. From every thoer satellite, I get no signal and no quality. What am I doing wrong?
I would double check you have entered your latitude (North) and longitude (West) correctly.
Also check the L.O. setting of your LNBF.
I merged this thread with your other. Please dont open a new thread for the same issue. Makes it too confusing to follow along :)
I have checked again. Problem still exist. I think my entries are correct. Here are my entries:
Lat: 29.7 N
Long: 95.3 W
L.O. ( I take it this means, LNB Low?) 1075....Invacom QPH-031 Quad LNBF
10750 for the LO frequency
Can you get G3 (which is right next door to IA5 and is your true south)
Make sure to use the following transponder to verify signal on G3
11780 freq
H pol
20760 symbol rate
Pardon my ignorance here Iceberg. This is precisely my problem. How do i enter these figures you are giving me? On my receiver, I do not see where to enter 11780 freq
H pol
20760 symbol rate
I do not see this in the Installation/Antenna Setup area. Can you point me to the right direction?
I havent worked on a viewsat in a while but Go into your antenna setup (where it lists your antenna optins, diseqc options, etc) and at the bottom it should have a list of transponders at the bottom
Scroll down and get into that box and you should be able to edit the transponder info. But I know the transponder I listed for G3 should already be in there. Check my review of the Viewsat 2000 (the original) in the review section for pictures. I think the Xtreme is set up the same, just has a couple other options
Lat: 29.7 N
Long: 95.3 W
L.O. = Local Oscillator
This should be 10750 with the linear (FSS) side of your QPH and 11250 with the circular (DBS) side.
would fta work in my area
pansat 2700a madness please help...
