Found something spiffy at the thrift store for a whopping $8; a USDigital DB-2010! It looks to be the $20 version, but it was previously activated. Yep, that means it's now a standard OTA HDtv reciever By the way, you can get one of these from Walmart for $20, activate it with the 30-day trial (USD charges your card $20), then cancel before the 30 days are up (USD refunds your $20). Ta-da, you own a $200 OTA HD reciever for $20! Just beware, Walmart won't accept them as returns if opened.
Well, anyway, mine works beautiful. My question is about tips & tricks. My 20-year-old rusty 6-element rooftop arial amazingly pulls in every single available digital signal listed on CheckHD.com and AntennaWeb.org. However, two of those stations (PAX KUPX-DT and FOX KSTU-DT) are too weak to watch. Originally I was missing several, and the signal came and went. So I replaced the aging old flat brown standard antenna wire with a peice of RG6 cable, and that made everything stable and left me only lacking those two stations.
What confuses me is that a lot of the other networks come from SLC, and I get 90%+ signal from them. I suppose PAX and FOX could have lower wattage broadcasts? I'm assuming my arial is pointed correctly, as everything else comes in so nicely. Would a line amp help? Should I simply accept the limitations, or purchase a newer antenna? Don't get me wrong, I'm thrilled with what I've got But as I'm so close to having everything "possible," I'd love to grab the last two.
Thanks for your input!
