Hooking up 2 receivers
schofield765
Can anyone give me info on how I can connect both my 5900 PVR and a 9241 HD PVR. Connection so far- 2 Dual LNB's each connected to SW21, 2 RG6 cables going into house and both plugged into 9241 HD PVR. Can I split off one of the RG6 ( with a switch ) and connect it to 5900 PVR? Any info would be great thank you.
You would need to replace your SW21 with a SW44 and run a new line from your 5900 PVR to the SW44. The lines cannot have splitters after the switches.
Ok i will look into that. Thank you very much
Yep, that is simplest way now to connect 2 receivers for sure.
Just replace BOTH LNBF's, remove the SW21, run 1 line to each Receiver, add the DPP Separator behind the 9241 and away you go. No Dish re-alignment as long as you don't move it when removing the old LNBF's.
No signal on Bell 82 using 9241 DVR in Boston
Will Shaw Direct do any dickering on their pricing...??
