I'm currently planning to try a mini bud with my 1M motorized dish using a bsc621 c/ku combo LNB & conical scalar ring with a Pansat 9200 in the bedroom. Sounds to be feasible from what I've read about mini bud's. But also sounds like the focus for an offset dish might not allow working for both C & Ku bands. If I can get it to work, I plan to buy a second set for my second 1M dish, motor & Pansat 9200 in the living room. And in that case everything is OK.
But if I find I can't achieve focus on both bands, I'm thinking an alternate route using a new 1.2M dish with motor. But here's the rub only two receivers, and three dishes and motors. Presently I have totally independent satellite and channel viewing in the two rooms.
So is it possible to control two motors from only one receiver w/o shutting off the receiver, disconnecting and re-connecting a second cable to the other motor? What kind of switch would I need?
Seems a dual output c band lnb could feed both Pansats, or would the stackable LNB be better? And just what is a stackable anyway?
Also in the mix are two 24" oval dishes with LNB's at 110, 119 & 129. Presently LNB selection is with a simple 1x4 Diseqc switch for each room's equipment.
