Dreambox Reality I PVR
Hardware:
LIAN LI PC-V880B Black Aluminum ATX Desktop Computer Case
PC Power & Cooling SILENCER® 360 ATX
TYAN S2507T, TIGER 230T, 694T, DUAL SOCKET 370, 5PCI, AGP4X, 4 DIMM
Intel Pentium P3 1.40 GHz 133 MHz 512 KB 370
19dB Nexus AXP-3200 Quiet CPU Fan for Socket 370
1GB of SDRAM
ASUS N6200/TD 256MB VIDEO CARD
Logitech® Cordless Desktop® EX 110
To save some money I decided to use ATA-100 vs. SCSI Ultra320…two 73GB SCSI drives $500, instead I decided to pick up two HITACHI SATA hard drives at a cost of $150, yes SCSI drives are twice as fast…but SATA drives are almost three times as big, more storage. There are no PVR receivers out on the market that come with 500GB 2 drives installed or setup as raid 1, yet. I will continue to modify this list of parts until I find an optimal performance level at a reasonable cost.
Promise FastTrak S150 TX2 Plus Serial ATA Raid Controller
HITACHI Deskstar T7K250 HDT722525DLA380 (0A31636) 250GB 7200 RPM SATA 3.0Gb/s Hard Drive
SAMSUNG 18X DVD±R DVD Burner with 12X DVD-RAM Write Black E-IDE/ATAPI Model SH-S182D
TechniSat DVB PCI Card The SkyStar 2
Software:
Microsoft Windows XP Pro
VMware Workstation 5.5
Fedora Linux Core 6
Step 1: Putting all the Hardware together
Install PC Power Cooling Power supply in the LIAN LI PC-V880B case is straight forward. Next install Tyan motherboard into the case, once again straight forward (I have done it a few times so don’t wary, it really is that easy). Next install CPU’s and CPU cooling fans, and memory (SDRAM). At this point install hard drives and DVD R/RW connect all power connections. Now we can start to installation of graphics card, then DVB card, and decent sound card, that all folks…unless I decide to add some other piece of hardware feature for future use…I will provide pictures for each one of these steps.
Step 2: Installing all the software
I will first install Microsoft Windows XP Pro as host operating system, and then WMware Workstation 5.5 and finally Fedora Linux Core 6. WMware runs multiple operating systems simultaneously on a single PC. Users can run Windows, Linux, NetWare, or Solaris x86 in fully networked, portable virtual machines - no rebooting or hard drive partitioning required. Note that before I install Linux I have to decide which of the two options to use…I will come back to this latter when I am actually installing. Not much needs to be added here since the software and the idea speaks for itself, just let your imagination take you where you want to be.
There are some options that I would like to see my Dreambox Reality I PVR machine project. Instant backup of the whole disk that contains all the operating systems and various software packages (2 disk RAID 1 can be an option, Adaptec - Adaptec ATA RAID 1200A or Promise - FastTrak S150 TX2)…for the PVR option a second disk (storing/recording) and one or two DVD burners will be used for burning of the stored movies, programs, etc....
If you have picture in picture on your TV you should be able to record programs in one window using Linux and surf the internet in the other using XP…and the Dreambox Reality I PVR with cordless keyboard and mouse combo from Logitech…That is a start…more details to follow…Now I have to save some money for the expensive parts…
Hardware:
1GB of SDRAM
Software:
Fedora Linux Core 6
