Background: Initial install had WAP connected to Hopper via ethernet. Distance from it to WJ was too far for consistent connection. The long room in which I have WJ has a coax at the opposite end of the room. I hooked that cable to a client port of the node and ran to a HIC, then connected to WAP. Signal is strong and no problems with them seeing each other.
The one problem since the re-hook up, is that WJ does not detect internet. Moca details in Diagnostics/Network show the HIC is NOT MOCA linked. Bridging IS enabled at hopper. I can find no way configure linking. Is this situation a trade-off for WAP not being connected directly to Hopper? Pass through port on HIC is not tapped. Should it be?
