It's been awhile since I installed my HH120 with a 90cm ku offset dish on it.
With the upgrade to a 120cm dish, I had to change elevation but I kept everything else (the dish mounting bracket alignment on the HH120 motor since I used the 90cm mounting bracket with the 120cm dish since they were identical) and I kept the hh120/dish to the mounting pole alignment since I didn't have to remove the motor.
I peaked elevation for center sat (0 position on HH120) and it's awesome (12 db signal/noise on my due south sat ku peaking reference dvb-s mux). On AMC-21, not so much (about 8.2 db on my reference PBS mux) so very disappointing. When I push up on the dish to increase elevation, signal level rises quit a bit so it tells me the arc falls off at least on the west end. I don't know where I stand on the east end yet as to whether I'm high or low of the arc on that end.
My HH120 motor elevation adjustment is correct for my latitude since I checked that setting. Can I pretend this is something like a big backyard dish alignment and assume my FS 120cm N/S axis is a little off and go to an extreme sat and loosen the bolts holding the dish to the HH120 tube and rotate it for maximum signal strength, and then go back and forth between 0 position and extreme sat position and work on getting the N/S axis set so that the arc has great signal throughout?
