I've just installed a hh120 motor with the disecq switch between the motor and lnbf. Using USALS mode the dish keeps oscillating between a good signal and no signal. Using disecq 1.2 I can't zero in on the signal.
Straight hook up works like a champ. Bad disecq? I've been using it on a fixed ku and C-band for years.
Also, I hooked up an encoda switch in place of the disecq, In setup, when I turn the 22khz off, signal level goes down to 45 - 50% and quality stays the same?
