I recently purchased a Slimline 5 LNB satellite kit for tailgating. The satellite I bought was a directv HD 5 LNBF. I received it today and put everything together to the best of my knowledge. I am definitely not a satellite guru so I went by what I saw with my house dish and with what I learned from the web and installation manual. I even read through the thread another guy had installing his just a few days ago. Hopefully you can help me like you helped him!
I am having trouble figuring out how the course knobs and fine adjustment knobs are for the tilt, azimuth, and elevation. Are those the little black knobs? I have gathered the info for my azimuth, elevation, and tilt from dishpointer.com. After putting everything together and leveling out my unit. I began adjusting the elevation and tilt by just loosening the bolts and then tightening them. I assume this is not correct, but I was getting confused by the manual's instructions. I then used a digital compass app to try to direct my azimuth, but I am not quite sure where I should set my phone to direct it. Should I place it on the lnb bar or what? I tried going through the dish installation on my receiver but I only get 0's for the 32 inputs on the 101. I hope you can help me. I am not terrible with electronics typically, but I have never worked with satellites before so hopefully I don't sound too bad. Thanks!
