Hi all - I am having trouble setting up a Shaw 605 receiver on a 60cm quad lnb dish down in the lower 48 (Arizona). I am using the Super Sat Buddy meter and am pretty confident I have the satellites pegged. My meter is indicating mid to high 70's signal on most all transponders, both satellites and using the ID verify function the meter reports back ID verified. I have pointed at 111 many times for use with the Wildblue system, and have pointed thousands of dishes in my career - but this is my first trying a shaw system. I get nothing at the receiver whatsoever. To rule out interior cable, etc I have a straight jumper from the LNB to the receiver and have verified signal at the receiver using the SSBM. When I hook into the receiver I get nothing, at all... I have plugged channel 299 in, also verified 4128 in the provider ID. What's odd is when I *remove* the sat feed, the point dish screen indicates signal - bouncing from 0 to 95 and everywhere in-between. Why would that be?? I've measured voltage off the port at 13.95 steady. Further, the LNB and dish is brand new - shows very minor LO drift (couple hundred kHz, dB's are in range, etc. ie: The LNB seems fine to me. Also, I've tried different ports at the LNB. The receiver came from the customers house in Canada and was working fine there (I don't know his dish setup there), so it is believed to be a good receiver. Any suggestions??? Does anyone know what transponder ch 299 comes down on so I can use that specific one to point at? What should the voltage measure off the back of the receiver? Is this even the right dish for this receiver? Thanks in advance for any replies!!
